Jan 14, 2024 2:25 PM UTC
ESI Error shows "Phantom CAD subassembly publication is not supported"
I am using Windchill Enterprise Systems Integration Release 12.1 and Datecode with CPS 12.1.0.0
While Publishing the code, there is this ESI Error shows "Phantom CAD subassembly publication is not supported"
Here are the errors that I faced
    avillanueva
    23-Emerald II
    Jan 15, 2024 1:48 PM UTC
    I would open a ticket with tech support. You might get the answer that is working to spec. If you do want this supported, I would submit an idea and indicate how you would want the ERP system to handle phantom CAD.
    avillanueva
    23-Emerald II
    Jan 16, 2024 12:09 PM UTC
    Hi, Please let me know. Need support
    When i check the BOM structure there is no Phantom CAD sub assembly that i can see.
