avillanueva
23-Emerald II
Dec 21, 2022 5:01 PM UTC
ESI Failure since user did not have create rights for Transaction
Side effect of flipping who creates out Change Notice objects. We had previous automated creation so wcadmin was the creator. We finally flipped back to more OOTB where uses can create (I do not use Change Admin roles). When the ESI workflow kicked off, it failed since the creator of the CN whom it uses in ESI did not have rights to create an ESI Transaction. Simple to fix by granting rights at the Org level in Systems domain like it suggested but strange that I had to do this.
2022-12-21 11:38:33,399 ERROR [SessionThread-825] wt.access.evaluation.report - "XXXXXXX" does not have Create permission for "Enterprise Systems Transaction - " in Administrative Domain "Site, Organization - MYORG /System".
2022-12-21 11:38:33,404 ERROR [SessionThread-825] com.ptc.windchill.esi.txn.ESITransactionUtility - Error while creating ESITransaction object.
(wt.access.accessResource/19) wt.access.NotAuthorizedException: ATTENTION: Secured Action. You do not have the necessary authorization for this operation. Contact your administrator if you believe you have received this message in error.
I would have thought it would have been handled by system.
avillanueva
23-Emerald II
Dec 22, 2022 12:48 PM UTC
Linking some other articles and posts I found on  this topic:
https://community.ptc.com/t5/Windchill/If-the-CN-Initiator-removed-from-the-License-groups-Termination/m-p/695357#M63061%3Fsource=search
https://community.ptc.com/t5/Windchill/What-is-the-purpose-of-the-ESI-Author-and-ESI-Administrator/m-p/330101#M38761
https://support.ptc.com/help/wnc/r12.1.1.0/en/index.html#page/Windchill_Help_Center/esi_admin/ESIAddUsersToGroupMapRoles.html#
One thing does have me a bit concerned is that if the CN initiator leaves the company before the CN is completed, will the ESI workflow always fail since the initiator does not exist? I will have to test this one out.
avillanueva
avillanueva23-Emerald IIAuthorAnswer
23-Emerald II
