Jan 23, 2026 11:40 AM UTC
ESI Response file not generating
I have installed Windchill with ERP connector. I have loaded a demo data while installing Windchill. There are OOTB distribution targets available on Windchill. I have created a part, assigned Distribution Target of Oracle type, then navigate to Action > Send to Distribution Target. I can see the message that Publication started, however there is no ESI Response file generated. I can see below log in BGMS.
] tasks.com.ptc.windchill.esi.export.ExportToJMSQueue  - Error while executing the Create-Object webject. (com.infoengine.util.IEResource/151) com.infoengine.exception.fatal.IEInternalServiceException: no ldap context found for administered objects.
at com.infoengine.messaging.MsgService.getInitialContext(MsgService.java:416)
at com.infoengine.messaging.MsgService.initializeQueueSupport(MsgService.java:368)
at com.infoengine.messaging.MsgService.getMsgService(MsgService.java:280)
at com.infoengine.webject.msg.CreateObject.invoke(CreateObject.java:23)
at com.infoengine.procunit.webject.WebjectProcessor.invokeWebject(WebjectProcessor.java:624)
at com.infoengine.procunit.webject.WebjectProcessor.processTask(WebjectProcessor.java:210)
at com.infoengine.SAK.Webject.invoke(Webject.java:492)
at com.infoengine.compiledTasks.file.D$3a$5cptc$5cWindchill_13$2e1$2e2$2e0$5cWindchill$5ctasks.com.ptc.windchill.esi.export.exporttojmsqueue$2exml.invoke(exporttojmsqueue$2exml.java:277)
at com.infoengine.SAK.Task.invoke(Task.java:1813)
at com.infoengine.SAK.Task.invoke(Task.java:1721)
at com.ptc.windchill.esi.txn.ESIResponseSender.run(ESIResponseSender.java:150)
at wt.session.SessionThread.run(SessionThread.java:225)
When i use Distribution Target of File type, ESI Response File is generated. It is only generated to for File type distribution target.
Fadel
23-Emerald II
Jan 23, 2026 12:37 PM UTC
is that no the same issue handled in support case C17996098 ?
Buiꓘa
Jan 23, 2026 1:55 PM UTC
yes
Fadel
23-Emerald II
Jan 23, 2026 1:59 PM UTC
Thanks for feedback , will review details/attachments on support case and let you know
Buiꓘa
