3-Newcomer
Jan 23, 2026 12:39 PM UTC
ESI Transaction Failure
I am using Windchill Enterprise Systems Integration Release 12.1 and Datecode with CPS 12.1.2.16
ESI Integration transaction status shows Failed and not generating Payload xml
Here are the errors that I faced
An error occurred while generating the ESI response. See the error logs for more information. Error message: The selected object "XXX" has not changed since it was last successfully published.
    MarcoTosin
    Jan 23, 2026 1:04 PM UTC
    This is Windchill's standard operation when the system checks the data to be sent against the last successfully sent version.
    If it finds no differences, it does not execute and write anything.
    Take a look also to this article
    Publishing object failed with error: "xxxxx" has not changed since it was last successfully published in Windchill Enterprise Systems Integration
    Marco
    MarcoTosin
    Marco
    Fadel
    23-Emerald II
    Jan 23, 2026 2:39 PM UTC
    This is expected you can't send same stuff twice to ERP ,try to revise the object and give a try
    Buiꓘa
    Catalina
    Community Manager
    Feb 4, 2026 7:49 AM UTC
    Hi @SS_10607365
    If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
    Catalina | PTC Community Manager
