May 4, 2024 2:40 PM UTC
Exception while creating Project
I am getting following exception while creating project,
Unable to roll back group members removal for the group <280_ORG> (wt.fc.fcResource/32) wt.fc.ObjectNoLongerExistsException: Cannot restore "wt.org.WTGroup.448789" because it no longer exists.
I have checked in WTGROUP Table for the ida2a2=448789, but there is no object with the mentioned ida2a2.
HelesicPetr
May 6, 2024 5:38 AM UTC
Hi @ST_10853935
Yes the table does not contain the table this is the case why the error is thrown
Update your Project template where the group is used.
PetrH
HelesicPetr
Hi @ST_10853935
PetrH
Emeritus
May 9, 2024 6:45 AM UTC
Hello @ST_10853935,
It looks like you have a response on your topic. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
