Jun 20, 2016 8:05 PM UTC
Export and Import dump from oracle - Issue
I have exported oracle dump and when I try to import I get the below issue..
import done in WE8MSWIN1252 character set and UTF8 NCHAR character set
import server uses AL32UTF8 character set (possible charset conversion)
IMP-00024: Only one mode (TABLES, FROMUSER, or FULL) can be specified
IMP-00000: Import terminated unsuccessfully
Any thoughts how to resolve this issue...
2-Explorer
Jun 20, 2016 11:07 PM UTC
Could you paste the import command which you used? It looks like multi modes were specified in the command
Jun 21, 2016 7:10 AM UTC
Here is the command...
imp test/test@XE file=C:/ptc/BACKUP/install/oracleDb.dmp full=yes fromuser=test touser=system
