Sep 22, 2023 10:30 AM UTC
Export Container Templates with code Windchill 12.1
I wanted to know, if there is a way to export Container Templates with code, or a windchill shell command.
I couldn't find anything in the knowledge base, that's why I wanted to ask in a post.
HelesicPetr
Sep 22, 2023 10:57 AM UTC
Hi @Leon_Dietz
Templates are clastic objects that have content and the content is XML. The content is an ApplicationData so you can use standard api to search the template and download it.
here is a code that gives you the content URL and download URL
QuerySpec queryspec;
String templateName="Product Design";
try
	queryspec = new QuerySpec();
	int idClassIssue = queryspec.appendClassList(DefaultWTContainerTemplate.class, true);
	CompositeWhereExpression andCondition = new CompositeWhereExpression(LogicalOperator.AND);
	andCondition.append(new SearchCondition(DefaultWTContainerTemplate.class, DefaultWTContainerTemplate.LATEST_ITERATION, SearchCondition.IS_TRUE), new int[]{idClassIssue});
	andCondition.append(new SearchCondition(DefaultWTContainerTemplate.class, DefaultWTContainerTemplate.NAME, SearchCondition.LIKE, templateName), new int[]{idClassIssue});
	queryspec.appendWhere(andCondition, new int[]{idClassIssue, idClassIssue});
	queryspec.appendOrderBy(new OrderBy(new ClassAttribute(DefaultWTContainerTemplate.class, DefaultWTContainerTemplate.MODIFY_TIMESTAMP), false), new int[]{0});
	QueryResult queryresult = PersistenceHelper.manager.find((StatementSpec) queryspec);
	while (queryresult.hasMoreElements())
		Object object = queryresult.nextElement();
		if (object instanceof Persistable[])
			DefaultWTContainerTemplate cam = (DefaultWTContainerTemplate) ((Persistable[])object)[0];
			ContentHolder syHold = ContentHelper.service.getContents(cam);
			Vector<ApplicationData> vectorOfAppData = ContentHelper.getContentListAll(syHold);
			Iterator<ApplicationData> appIter = vectorOfAppData.iterator();
			while (appIter.hasNext())
				ApplicationData syAppData = appIter.next();
				ContentHolder holder = ContentHelper.service.getContents(cam);
				final URL viewContentURL = WVSContentHelper.getViewContentURL(syAppData, holder);
				final URL downloadURL = WVSContentHelper.getDownloadURL(syAppData, holder);
} catch (QueryException e)
	e.printStackTrace();
} catch (WTException e)
} catch (PropertyVetoException e)
	throw new RuntimeException(e);
PS: how to get inputStream
InputStream stream = ContentServerHelper.service.findContentStream(syAppData);
PetrH
HelesicPetr
Sep 22, 2023 10:32 AM UTC
Hi @Leon_Dietz
The Container Template ? so you need to download a XML definition of product/Library template?
am I  Right?
PetrH
Sep 22, 2023 10:42 AM UTC
Yeah at the end I need Product/Library/Project Templates inform of xml Files, I could also create a xml file by hand, but I was wondering if there is another way already implemented within the windchill api.
HelesicPetr
Hi @Leon_Dietz
try
PetrH
