Feb 14, 2020 4:31 AM UTC
Export Import Object Types
If you refer to article https://www.ptc.com/en/support/article/CS30168 it says to export your files and then import them in numerical order. I can get to step 4 successfully.
As soon as I try and import the file numbered _0 it fails with wt.util.WTException: Invalid Name: "local.rs.vsrs05.Regain" is incompatible with the domain context "null".
local.rs.vsrs05.Regain is the organization internal name.
I gather file _0 contains the global attributes which in my case exist on the target machine. I would not expect it to error, I would expect it to do nothing in my case.
FIle _1 contains the attributes form the object type parent but it will load successfully, even though it also does nothing in my case.
File _2 does load successfully and does create the object correctly, even if I do not load file _0 and file _1.
Additionally, I need to specify the organization in the loadfromfile command otherwsie it bombs out.
Does anybody know how I cna load the first file, and load attributes that do not exist already?
I'm afraid it is another case of the documentation missing something critical to make this work. I personally have not found any documentation that is foolproof. There is ALWAYS something missing or something assumed.
I will however habve cases whw
Aug 31, 2026 6:14 AM UTC
After 6 years I’ve tried to do this again. Still get the same errors.
If you use the CONT_PATH =\"/wt.inf.container.OrgContainer=<YourOrgName>\" it will bomb out on file 0.
File 1 and file 2 seemed to work, so from now on I’m goign to ignore file 0 which appears to be the golbal attributes, ensuring I have them the same on both dev and production and just run files 1 and 2 which take care of the object types.
HelesicPetr
Sep 2, 2026 9:53 AM UTC
Hi ​@bmessenger
Interesting, I’ve never ever had any troubles with exporting and importing process as you described.
I use the load from file command without organization definition
windchill wt.load.LoadFromFile -d D:\export\WTPUSAGE_0.xml -u user -p pas
windchill wt.load.LoadFromFile -d D:\export\WTPUSAGE_1.xml -u user -p pas
windchill wt.load.LoadFromFile -d D:\export\WTPUSAGE_2.xml -u user -p pas
PS: you can not use the exported definition in different windchill version
PetrH
