Mar 4, 2025 11:53 AM UTC
Export/Import Workflow Template
Version: Windchill 12.0
Use Case: Hello, We want to export and import workflow templates between Windchills with different versions. Is there a table showing version compatibility for this?
Description:
18-Opal
Mar 4, 2025 12:41 PM UTC
@BERKAY
Which version are you exporting from?
Which version are you importing to?
I’ve had to do this several times between 13.x and 12.x.
I’ve not tested beyond those releases but I can tell you it was not difficult to do it.
BERKAY4-ParticipantAuthor
Mar 5, 2025 6:06 AM UTC
Hi Graham,
Thank you for your answer.
One version 12.0.6 and the other 13.0.2
avillanueva
23-Emerald II
Mar 4, 2025 12:47 PM UTC
There is some good information and settings there:
http://support.ptc.com/help/windchill/r13.1.0.0/en/index.html#page/Windchill_Help_Center/workflow/WFTemplatesImport.html#wwID0EWICX
No backwards compatibility.
Mar 5, 2025 6:08 AM UTC
Hi Avillanueva.
Thanks for the link, I will examine.
