Mar 20, 2013 5:48 PM UTC
Exporting Global Organizers/Attributes
Is there a command line utility to export Global Organizers and Global Attribute definitions? I thought for sure that there was but I'm unable to find it.
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image001.jpg@01CE2571.9CA95BC0]
Mar 20, 2013 7:36 PM UTC
You can export type,type attributes, are on along with the layout config. How to in help center. Not sure if this is what you need. Have to create a loadfile xml export rule.
Sent from my Verizon Wireless 4G LTE Smartphone
Mar 21, 2013 3:57 PM UTC
Yea the command “windchill wt.load.LoadFromFile –D ExportDefinition.xml” won’t get me the definition of the global attribute definitions themselves.
[cid:image001.jpg@01CE262B.4D1E3E80]
ScottMorris
Mar 22, 2021 7:09 PM UTC
wow, so sad to see this is a dead thread from 8 years ago. i would really like to export my full set of reusable (global) attributes to have as a backup and source of truth for unintended changes. i'll keep searching...
Mar 22, 2021 8:35 PM UTC
Not sure I follow the request.  Today Definition Exporter does get global enumerations associated with the object type being exported.  I just did this today between test and staging 11.2 environments.
You can also export Global Enumerations directly.
https://www.ptc.com/en/support/article/CS33940
