Feb 9, 2016 3:41 PM UTC
Exporting PDF's
I know many on these boards use Fishbowl's LinkAccess Trigger.
Does anybody know if PTC has any plans to  come out with something similar in the near future or if it's even a consideration?  Can anyone from PTC comment about any plans in this area?
Feb 9, 2016 3:46 PM UTC
We are using Creo View Adapters to create pdfs and attaching them to the representations in Windchill. We do also use some tools from Fishbowl to stamp WTPart info on to that PDF. So we use some stuff in combination.
STEVEG21-Topaz IAuthor
Feb 9, 2016 3:49 PM UTC
Andy,
That is an interesting idea.  But we are looking to export PDF's of our drawings upon a certain state change.
TomU
Feb 9, 2016 3:53 PM UTC
Apparently I was typing my reply while you posted this...
Although I haven't personally done it, I've been told that you can write a workflow in such a way that it can do this - basically dump an object out to a network folder somewhere.
TomU
Feb 9, 2016 3:51 PM UTC
I'm not from PTC, but I will share a couple of observations.
  • PTC is probably not going to develop anything that automatically dumps data outside of Windchill (like PDFs to a network folder).  Once you do that you lose all control of the data.  No way to make sure you have the right version or apply access controls.
  • Windchill already has the capability built into it to generate any type of PDF you want, whenever you want.  You can create them during check-in, during state change, during workflows, etc.  You can also create them in different configurations (latest, as-stored, baseline, etc.)
  • Windchill already provides access to these PDFs from an object's content page.
  • To make it even easier, PTC has also released the "PTC Navigate" Apps.  These provide one-click access directly to the different representations of an object (PDF, DXF, IGS, STP, JPG, STL, etc.)
Edit:  Here is a video demo of the PTC Navigate Apps:  PTC Windchill 11 Telecast: Part 4 | PTC
Feb 9, 2016 4:03 PM UTC
That Navigate App does sound promising.  Our company doesn't let us watch any videos so I'll have to watch it on my phone or at home.
Side note: PTC has started to release some videos as flash.  This seems to by-pass that restriction of playing videos.  At least at our place for now.
AndrewDunk
6-Contributor
Feb 9, 2016 6:04 PM UTC
Hi Steve, I work with a partner of PTC's. I'm excited about PTC's apps although I believe they require some sort of licensing for thingworx to utilize. I should be able to research this more I'm not exactly sure just yet.
Another alternative could be working with us. We partnered with a company called Wincom and develop similar "apps". We just had a webinar that talked about our "Content Export" app which gives you a quick wizard on top of Windchill where you can select and export various file formats. For example you could select an assembly and within that choose where and what you'd like to export (Step,IGES,DXF) or create PDFs if needed. When you get a chance check out 22:40 in this video. We can also set up triggered publishing from different lifecycle states.
Recorded Webinar Windchill Apps Series 1: Automating Common PDM Tasks & Enhancing User Experience - YouTube
- Andrew
- Andrew "Dunk" Dunkelberger
Feb 9, 2016 6:32 PM UTC
It's good to have options so thank you for posting.  I'll keep it in mind.
