2-Explorer
Apr 23, 2014 6:02 PM UTC
Exporting relationship constraints
Is there a way to export relationship constraints into an xml file so that they can be imported into a different environment? I can export the link type definition, but it doesn't include relationship constraints. Any ideas?
GregoryPERASSO
Apr 25, 2014 6:40 AM UTC
in 10.0 it was not possible ... as you said ... link type definition but not relationship constraints ...
need to create the XML manually
for example
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE NmLoader SYSTEM "standardX20.dtd">
<NmLoader>
<!-- ** Configurable Link Valid Relationships ** -->
<csvCreateDefaultAssociationConstraintItem handler="com.ptc.core.meta.type.mgmt.server.impl.association.LoadDefaultAssociationConstraintItem.createDefaultAssociationConstraintItem" >
<csvlinkType>com.richemont.MyLink</csvlinkType>
<csvroleAType>com.ptc.myWTpart</csvroleAType>
<csvroleBType>com.ptc.myObject</csvroleBType>
</csvCreateDefaultAssociationConstraintItem>
</NmLoader>
Apr 25, 2014 3:39 AM UTC
windchill wt.load.LoadFromFile -d DefinitionExporterType.xml
export all Attribute Definizer and LWC Constraint rule.
tstacy2-ExplorerAuthor
2-Explorer
Apr 25, 2014 4:53 PM UTC
That command only exports the link type definition, not the relationship constraints. Thanks anyway.
GregoryPERASSO
for example
<NmLoader>
</NmLoader>
2-Explorer
Apr 25, 2014 4:55 PM UTC
That's what I thought. Thanks for confirming it. I have created my XML manually. Thank you.
