Jul 17, 2015 7:16 PM UTC
Extending the modeled attribute string length well beyond 500 charater limit
Has anyone done this?  I have a request that a document type be transferred into Windchill (essentially getting rid of the document by not having primary content), the content would be entered as attributes.  The question is, has anyone done anything like this?  One of the attribute strings would need to be increased to allow 4-5 thousand characters.
2-Explorer
Jul 18, 2015 11:19 PM UTC
We have increased an attribute to hold 1000 characters, however never tried to hold the contents of entire document.
We followed the method mentioned in Customizing Column Length .
Binesh Kumar
Barry Wehmiller
2-Explorer
Binesh Kumar
Barry Wehmiller
Jul 20, 2015 7:21 AM UTC
The max is 4000 characters.
GregOlson16-PearlAuthor
Jul 20, 2015 11:02 AM UTC
Is there any downside to doing this?  You have fully tested this and running in production?
Jul 20, 2015 12:17 PM UTC
I just said that the max is 4000 characters. You won' t be able to set the size to 5000. We run this also in production mode.
I still hope that finally a WYSIWYG arrives. Then you can also document the changes etc. in a change object itself!  I would love to see that!
Jul 22, 2015 11:58 AM UTC
Do you need InfoModeler to change the database?
BenPerry
Jul 22, 2015 1:27 PM UTC
Greg Olson,
According to my experience, and Guilherme Rocha‌, InfoModeler is no longer required.  I would've needed it in 9.1.  But it worked without InfoModeler when I tried in 10.2.
We can refer to this discussion: 80 character limit.
Jul 22, 2015 2:19 PM UTC
Ben, does your testing confirm the below situation?
Increasing the character length will involve making changes to the StringValue database table. The catch in this is that all the string valued attributes across Windchill are stored in this table. Increasing the character limit on this table to 4k, would mean we are increasing the character limit for all the string attributes in Windchill to 4k – which would be an undesired condition. So to control the length of all the other string attributes suppose we introduce a character limit of 500 on them. But this might have some performance impact because then Windchill will have to apply the limit validation to all those strings before displaying them on the screen. In short we the situation will be that all the string attributes in the system will be of 4k length, and excepting one or two, we are putting a limit on all the others to limit them to 500.
MarcoTosin
Jul 28, 2015 8:40 AM UTC
This is last article from TS talking about 4000 characters limit.
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS213940
Marco
