8-Gravel
Jan 19, 2026 5:34 PM UTC
Extracting family table details from Windchill PDM 12.1 database using SQL Query
Version: Windchill 12.1
Use Case: Need to extract the generic and instance family table data
Description:
I have already referred article: Article - CS284331 - How to get QML Report/SQL Query to get CAD Generic Part and its corresponding Instance parts in Windchill PDMLink
But in our database, we have different tables related to  family table:
1. EPMSepFamilyTableMaster 2. EPMSepFamilyTable 3. EPMFamilyTableMember.
I formed below query, but it was not successful because it's not retrieving all family table data and also the instance name is incorrect.
SELECT
    master.name AS parent_name,
master.createStampA2 AS parent_create_date,
    master.modifyStampA2 AS parent_modify_date,
ft.versionIdA2versionInfo AS version_id,
    ft.iterationIdA2iterationInfo AS iteration_id,
ft.statecheckoutinfo AS checkout_state,
member.title AS member_title
FROM
    pdmlink.EPMSepFamilyTableMaster master
INNER JOIN
    pdmlink.EPMSepFamilyTable ft
    ON master.idA2A2 = ft.idA3masterReference
INNER JOIN
    pdmlink.EPMFamilyTableMember member
    ON ft.idA2A2 = member.idA3A3
ORDER BY
    master.idA2A2, member.idA3A3;
Could you please correct above query or provide me some other table names which I can use to retrieve the generic and instance relationship from database. Thank you.
MarcoTosin
Jan 20, 2026 7:17 AM UTC
MarcoTosin
Feb 27, 2026 9:56 AM UTC
Did you read the article I wrote in the comment and check if it helps answer your question?
Marco
Community Moderator
Mar 9, 2026 7:40 PM UTC
Hi @Vignesh_AJ_77,
Anurag
