6-Contributor
Jun 20, 2017 12:26 PM UTC
Failed to build part error - HELP please
- 6 replies
- 6304 views
- Translate All
When I do a RIGHT CLICK to Build Associated Part, I will sometimes get this error. Any suggestions?
The image attached, I'm basically Right Click, Build Associated Part, then I get that error. The 12600453-6314.prt is RELEASED now, so not sure if the state change caused some issues. I've had this happen before, and the only fix was to modify a part at released (basically do any random change to generate a new iteration), but that cannot be the soltution.
FYI, the 12600453-6314.prt is related as a IMAGE. (We basically have a bunch of different tie wraps that are modeled and used to build the BOM).
