11-Garnet
Oct 4, 2024 10:34 AM UTC
Failed to push to SAP reallocated component to different operation
I have re-allocated the component to the different operation, however it is failed.
Followed below steps:
Step 1:
Created Process Plan (PPL00123) , there are operations in the structure (0111, 0112, 0113 etc..,), allocated component to operation 0111. Pushed to SAP >>> Succeeded.
I can see allocated component into "AddedOprBomAllocatedParts"  this tag of XML with operation 0111.
Step 2:
Revised Process Plan and operation, removed the allocation from 0111, Allocated component to operation 0112., removed the operation 0111 from the process plan structure.  pushed to SAP >>> it is failed.
I can see the allocated component into "UnchangedOprBomAllocatedParts" tag of XML. with operation 0112.
If I do not remove the operation 0111 from Process plan structure, it would succeed.
Should re-allocated be available in the  "changedOprBomAllocatedParts" tag of XML? or Am I missing something?
Can someone please help ?
MarcoTosin
Oct 4, 2024 10:38 AM UTC
I can't help you with this specific problem, but who could, needs to know what version of Windchill you are working on and what CPS is installed.
Marco
K_Patil11-GarnetAuthor
11-Garnet
Oct 7, 2024 3:27 AM UTC
I am using 11.1 M020 CPS22
Catalina
Community Manager
Oct 11, 2024 8:27 AM UTC
Hi @K_Patil,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina | PTC Community Manager
