Oct 24, 2025 8:32 AM UTC
Failure in Import
Version: Windchill 12.1
Use Case: Import preview started... Started object creation process... Object com.ptc.windchill.option.model.OptionMaster:5369119680, A exists with the UFID that is different than the UFID from XML THE RESULT OF THE IMPORT :FAILED
Description:
Oct 24, 2025 9:52 AM UTC
Oct 24, 2025 9:57 AM UTC
i have already tried resolve overridable conflicts but it didnot work out same issue again.
I even tried to locate but its referring to a ufid or some option which is not found on UI or in logs, getting same error in logs also
avillanueva
23-Emerald II
Oct 24, 2025 3:44 PM UTC
Can you add some detail like what you were importing and how?
