Nov 6, 2015 8:20 AM UTC
Fault Tree Analysis - WQS (Relex)
I have created a number of fault trees, set parameters and run the FTA model.  I have my FTA results.  I wish to see the cut sets of my fault tree and have used the highlight cut sets feature.  Relax shows me a cut set list in one single column which is not useful when I wish to see the minimum cut set in the diagram to send to our customer.
Does anyone know how I can export the minimum cut set and relate the list to the diagram so I can send them to our customer?
Nov 27, 2015 10:31 AM UTC
Duncan,
-make sure that you checked the "cut sets" check box in the calculation section, then calculate the fault tree.
- right click the top gate / properties.
- select the cut sets heading. A tabular representation of all cut sets will be displayed.
Nov 27, 2015 10:35 AM UTC
Duncan,
make sure that you enabled the "cut set" check box in the calculation section.
Right click the top gate / properties:
Note that Excel button.
