May 12, 2016 6:09 AM UTC
File Based Series : Remove Delimiter and increase the depth for versioning
Hi All,
I had created a series in this way as I had started a discussion regarding the same.
File Based Series : The series or seed is undefined
However I even wish to remove the delimiter say for suppose as upon revising or check out and check in it gets modified as V1.1 V1.2
So I dont want that delimter dot (.) to be there. I had seen the PTC Tech support portal for this and found few cases
Step 1.)
I went to wt.properties file and found the property. I made two modifications in wt.properties file
wt.series.HarvardSeries.delimiter=.
So I removed the dot and equaled it with nothing as
Step 2.)
wt.series.HarvardSeries.depth=16
So I updated the depth as 99
wt.series.HarvardSeries.depth=99
But after this the method server failed starting which is showing an error like
2016-05-12 11:36:27,662 INFO  [main] wt.system.err Administrator - Error initializing wt.series.HarvardSeries
2016-05-12 11:36:27,701 INFO  [main] wt.system.err Administrator - java.lang.StringIndexOutOfBoundsException: String index out of range: 0
2016-05-12 11:36:27,721 INFO  [main] wt.system.err Administrator - at java.lang.String.charAt(String.java:686)
2016-05-12 11:36:27,723 INFO  [main] wt.system.err Administrator - at wt.series.HarvardSeries.readStaticProperties(HarvardSeries.java:1042)
2016-05-12 11:36:27,728 INFO  [main] wt.system.err Administrator - at wt.series.HarvardSeries.<clinit>(HarvardSeries.java:164)
2016-05-12 11:36:27,729 INFO  [main] wt.system.err Administrator - at java.lang.Class.forName0(Native Method)
2016-05-12 11:36:27,751 INFO  [main] wt.system.err Administrator - at java.lang.Class.forName(Class.java:171)
2016-05-12 11:36:27,752 INFO  [main] wt.system.err Administrator - at wt.series.Series.getClassForName(Series.java:309)
2016-05-12 11:36:27,752 INFO  [main] wt.system.err Administrator - at wt.series.MultilevelSeries.newMultiLevelSeriesFromSeriesName(MultilevelSeries.java:554)
2016-05-12 11:36:27,753 INFO  [main] wt.system.err Administrator - at wt.series.MultilevelSeries.newMultilevelSeries(MultilevelSeries.java:210)
2016-05-12 11:36:27,754 INFO  [main] wt.system.err Administrator - at wt.vc.VersionControlHelper.<clinit>(VersionControlHelper.java:141)
So how to remove the delimiter for the custom_series class that I had created.
Thanks in advance. Kindly let me know
Thanks and Regards,
Aditya Achanta
aachanta15-MoonstoneAuthor
May 16, 2016 8:17 AM UTC
Hi All,
Can you please help me out like how to resolve this problem in delimiter.
Actually I had attached one more post to this particular query and I was in a position to create a new File Based Versioning Scheme. However if I wish to remove the delimiter like what should I be doing can you please let me know about it once ?
Thanks and Regards,
Aditya Achanta
May 16, 2016 8:39 AM UTC
Archana,
I don’t know your exact business requirement to implement this. If your requirement is
  1. Display only Revision and hide – check type and attribute managed layout and override the version
  2. Display version by eliminating delimiter -  Use data utility to remove the delimiter and display version as A2 instead  of A.2
It always risk to play with versioning series.
Hope it helps!!!
Shreyas
