Jun 30, 2016 6:03 PM UTC
File Name of a document from Query Builder
I wanted to create a report that shows the File Name of a document but it's not listed.  Is there a way to get that in a query builder report?
Background:
Some of our documents are not publishing.  I created a call with PTC to see if we can figure out why.  It turns out that the macro-enabled Office documents are not supported by Adobe LiveCycle.  DOCM, XLSM, PPTM.
I wanted to find out how many of those types of documents we have in our system.  I did a keyword search but that returns other documents that are not those types.  However, even though they are not supported the majority of the DOCM files that came back in the search did get published.
When we migrated our documents a few years ago the Number field matched the File Name and the file extension is included in the Number field.  But anything since then doesn't get the file extension added in the Number field.
22-Sapphire I
Jun 30, 2016 9:55 PM UTC
May be able to show filename in search results.  I recall that getting the file name using query builder reports was just a bit tricky.  Have to go thru Application Data and Maybe Stream Data.  Can easily get the vaulted filename (hashed) thru FVITEM but that doesn't help for current need.
22-Sapphire I
MarcoTosin
Jul 1, 2016 6:23 AM UTC
Marco
2-Explorer
Jul 1, 2016 12:47 PM UTC
We can run query like this select filename from applicationdata where filename like '%.docm%';. Link application data to wtdocument using holdertocontent.
Regards
Binesh Kumar
22-Sapphire I
Jul 1, 2016 3:19 PM UTC
This is helpful.  A bit of a tangent, but I'm finding we have a long history of users renaming and leaving the extension (e.g. .PRT) off of the Number field.  I'd like to find all of these, and so thinking of a simple query builder report for EPM Doc joined to applicationdata with the criteria that EPMDoc.Number <> applicationdata.filename.  Would this work?  I haven't been able to quite get it working yet.
thanks in advance
screen capture
the database just lists the placeholder - different for CAD vs. WT Docs
20-Turquoise
Jul 1, 2016 8:57 PM UTC
You could also run a simple database query:
select cadname,documentnumber from epmdocumentmaster where UPPER(cadname) != documentnumber;
STEVEG21-Topaz IAuthor
Jul 5, 2016 12:24 PM UTC
Mike,
You showed the Application Data is what gives the File Name.  That is great so thank you.  However, the actual thumbnail files are also listed.  Any idea how to get rid of them from the reports?
For example I have these 3 files listed:
123.xlsx
MarcoTosin
Jul 5, 2016 1:46 PM UTC
Steve,
in criteria use Not instead of = or Like.
This way you can exclude jpg or other file extensions from results.
For example we have a document with State like color (White, Black, Red, Blue)
Using Not criteria we report only for some state, not for all.
Marco
Jul 5, 2016 4:20 PM UTC
But we have many jpg files in our system that are legitimate so that won't work.
I've been trying to figure out if it is a different type than the document but they come up as the same.
