Apr 18, 2024 9:53 AM UTC
File vault Manual sync
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020 CPS30
No of Cached files are not changed even after did a manual sync thru JConsole.
HelesicPetr
Apr 22, 2024 7:41 AM UTC
Hi @spitchan
The cached files could be not referenced file anymore so the synchronization is not needed.
PetrH
Emeritus
Apr 22, 2024 7:24 AM UTC
Hi @spitchan
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
HelesicPetr
Hi @spitchan
PetrH
spitchan13-AquamarineAuthor
Apr 22, 2024 3:19 PM UTC
What does it mean by referenced files?..you mean referenced in any other Assembly ? We tried running the
Go to JConsole > wt.method.Method Server Main* MBeans > com.ptc > Monitors > Cache Vault Synch > Operation > SysForceSync.
But still the cached files are not reduced.
HelesicPetr
May 20, 2024 6:19 AM UTC
Hi @spitchan
You could use delete unreferenced files.
PetrH
