3-Newcomer
Jul 6, 2023 8:52 AM UTC
filter failure
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.0
The visualization of parts and the visualization of the parts to be allocated in the lower left corner of the process plan executes the Filter filter code, and the visualization after allocation on the right side of the process plan does not execute the Filter filter code. What is the reason for this, and how to solve this problem, thank you!
Translated by the Community Moderation using Google Translate
部件的可视化和工艺计划左下角待分配部件的可视化执行Filter过滤器代码,工艺计划右侧分配后的可视化不执行Filter过滤器代码,这个是什么原因导致的,如何解决这个问题,谢谢!联系电话为:15684136086 李坤
Fadel
23-Emerald II
Oct 2, 2023 3:40 PM UTC
Would you add some screenshots to better understand the issue ?
Buiꓘa
18-Opal
Oct 27, 2023 5:04 PM UTC
Hello BJ_10148567,
This is Charles from PTC Technical Support in Europe.
Was the information provided helpful somehow?
KR,
Charles.
