Apr 7, 2025 8:01 PM UTC
Find Lifecycles assign to an object
Version: Windchill 13.0
Use Case: Determine the lifecycle associated with an object in Windchill.
Description:
We have multiple Lifecycles from the original administrator and I'm trying to find which ones have been used by objects so I can reduce the number of old lifecycles.
Is there a method to do a search in Windchill by Lifecycle to return which objects it is associated with?
My second possible search would be in the Oracle tables but I don't really have any idea where to start with them in SQLDeveloper. I do have a test system that I can play with so all my production data is safe.
Apr 8, 2025 3:26 AM UTC
try with below SQL
SELECT
pm.WTPARTNUMBER AS "Part Number",
ltm.name AS "Lifecycle Name",
lt.ITERATIONIDA2ITERATIONINFO AS "Lifecycle Version"
FROM
WTPart p
JOIN wtpartMaster pm ON pm.ida2a2 = p.IDA3MASTERREFERENCE
JOIN LifeCycleTemplate lt ON lt.ida2a2 = p.ida3a2state
JOIN LifeCycleTemplateMaster ltm ON ltm.ida2a2 = lt.IDA3MASTERREFERENCE;
also you can create QML report to get the details of lifecycle assigned to object. attached is sample report for WTPART.
Hope this helps.
joe_morton
Apr 8, 2025 6:31 PM UTC
You can also do this using query builder. It's just a join from the Life Cycle Template, to the object:
