Fadel
23-Emerald II
December 31, 2024
Finding Bom Headers
Hello All,
This is not a question just somethinh I want to share maybe someone will need it in the future .
 OOTB we have the  endItem attribute however its doesn't really mean that that part is a BOM header (Not used in other BOMs) and was looking for a way to find these BOM Header Parts .
I could achieve this in a two step manupulation .
First I have defined  a string  alias attribute called whereused to find the parents of a given parts with below mapping :
masterReference@wt.part.WTPartMaster~uses@wt.part.WTPartUsageLink~usedBy^wt.part.WTPart~number
Then a second step we can define a boolean calculated attribute  isBomHeader with formula : isNull(whereused)
We can now run a report find the BomHeaders :
Happy new Year :
Fadel
FadelAnswer
23-Emerald II
May 28, 2025
I does not  look if is it has component or not ,just that the part is not used anywhere
Buiꓘa
avillanueva
23-Emerald II
May 28, 2025
By BOM Header, you mean top level assemblies? In other words, Parts that are not used anywhere else? Does this also take into account if the Part itself has components? I would think both would need to be true. Reply to close out this thread and mark complete.
Fadel
Fadel23-Emerald IIAuthorAnswer
23-Emerald II
May 28, 2025
Buiꓘa
