Aug 27, 2018 4:22 PM UTC
First publish job always fails after Windchill restart
I've been working on getting our publishing under control and for the most part (with help from the great people and content here) things are going well. However, for whatever reason whenever I restart Windchill the first publish job always fails with the "Failed to register Windchill server xxx - - 15" error. Normally, I just republish that first job after a minute or so and things then start working well.
Is there a way to avoid this first job failing? Does it have to do with the order of events of restarting Windchill?
22-Sapphire I
Aug 27, 2018 4:38 PM UTC
In the CAD Agent configuration, make sure you have AutoStart checked.
Dobrisa1-VisitorAuthor
Aug 27, 2018 4:51 PM UTC
Both the Creo and Solidworks workers are set to Autostart.
The start up time for the Creo is set to 30 seconds... perhaps this should be longer??
Aug 27, 2018 5:02 PM UTC
My Creo startup time is set to 90 seconds.
