Mar 19, 2026 3:57 PM UTC
Fixed Product and fixed path in OIR for WTPart
Version: Windchill 12.1
Use Case: Dear All, In the Windchill 12.1.2.17 was possible to configure a fixed product and fixed folder path to create WTPart. I need that all WTPart will be stored automatically in one product context under specific path MyProduct -> /MaterialMasters/ElectronicComponents Can you help me to define it in OIR?
Thank you Enrico
Description:
Dear All,
I tried with this sintax but it doesn't work
<!-- FOLDER -->
<AttrValue id="folder.id" algorithm="com.ptc.core.foundation.folder.server.impl.FolderPathAttributeAlgorithm">
<Arg>MyProduct</Arg>
<Arg>/MaterialMasters/ElectronicComponents</Arg>
</AttrValue>
Thank you
Enrico
TDTAnswer
18-Opal
Mar 21, 2026 6:13 AM UTC
Hi @ENRICORIPAMONTI,
There is no straightforward solution to implement this requirement.
Please refer to the following article to configure the usage of specific types for particular products.
https://www.ptc.com/en/support/article/CS258467?source=search
To configure the automated folder path, please refer to the following article.
https://www.ptc.com/en/support/article/CS21487?source=search
Fadel
23-Emerald II
Mar 19, 2026 6:05 PM UTC
Are you sure ?
The OIR connont set context it sets only the subfolder. The context will be always the launch point from  where the create action is done
regarding syntax take a look at ,  you need  to  set attribute constraint to
https://www.ptc.com/en/support/article/CS226628
Buiꓘa
Mar 23, 2026 8:51 AM UTC
I'm aware of what you're saying, but my requirement is to have users always create all WTParts in the same context and the same folder path, regardless of the context they are currently in.
We have more than 1,000 contexts and users do not have full access, which they instead have — and must have — on the master data context.
Thank you anyway for your answers.
TDT18-OpalAnswer
18-Opal
