Apr 7, 2022 2:43 PM UTC
FlexibleChangeItemReadinessDelegate: which jar?
Hi team,
In the help page
http://support.ptc.com/help//windchill/whc/whc_en/index.html#page/Windchill_Help_Center%2FChgMgmtChgAssocConvertCustom.html
towards the bottom there is some sample code:
public class CustomReadinessDelegate extends FlexibleChangeItemReadinessDelegate {
We are trying to compile something similar to this but FlexibleChangeItemReadinessDelegate is not in our classpath.
$ javac -cp ../srclib/tool/Annotations.jar:../srclib/*:../codebase com/myco/dept/change/flexible/MyReadinessDelegate.java
com/myco/dept/change/flexible/MyReadinessDelegate.java:8: error: cannot find symbol
public class MyReadinessDelegate extends FlexibleChangeItemReadinessDelegate {
 symbol: class FlexibleChangeItemReadinessDelegate
Which Windchill 12.0.2.3 jar contains this delegate?
thanks -- Rick
HelesicPetr
Apr 8, 2022 10:56 AM UTC
Hi @rleir
It is in wncWeb.jar
This jar is located in <wthome>\codebase\WEB-INF\lib
my Windchill lib version is 12.0.2.0
PetrH
HelesicPetr
Hi @rleir
It is in wncWeb.jar
PetrH
20-Turquoise
Apr 8, 2022 5:11 PM UTC
Teaching a man to fish...
You can use the which command:
https://www.ptc.com/en/support/article/cs34287
[root@wct01 /]# windchill wt.util.jmx.Which wt/change2/flexible/FlexibleChangeItemReadinessDelegate.class
URL: jar:file:/opt/ptc/Windchill/Windchill/codebase/WEB-INF/lib/wncWeb.jar!/wt/change2/flexible/FlexibleChangeItemReadinessDelegate.class
 Last Modified: Fri Feb 11 15:28:20 CST 2022
 CRC: 2245216837
[root@wct01 /]#
rleir17-PeridotAuthor
Apr 11, 2022 10:55 AM UTC
Hi Petr, Randy @Jaime_Lee
How can I mark two answers as both presenting the solution?
I will try by accepting both in sequence, and maybe both will end up as 'accepted'.
thanks -- Rick
Apr 11, 2022 10:58 AM UTC
Hmm, that makes it impossible to mark Randy's answer as a solution, even though it is a valuable introduction to the 'Which' command.
Many thanks Randy!
