Nov 10, 2016 3:07 PM UTC
FRACAS Incident - assign a user group by other user group
Hi all,
working with Windchill 11.0, FRACAS, trying to get some kind of "Workflow" done, but as complete newbie I hit a wall. We have two user groups for web access (Incoming, Production). The idea was as follows:
Production user enters incident (user group production) through a Production Incident Form -> last step is to push a button and to transfer it to Incoming Dep. (or any other department) (calculation: assign entry to user group "Incoming Inspection").
Incoming user gets now the new entry displayed in the Incoming Incidents Table and can create a Fault Report based on the data.
-> Trick: The Production user should only see production entries, the incoming user only Incoming entries.
If I am logged in as Admin, the switching of assignments works. But If I am logged in as Production user, it appears that I can not change the user group. This might be a misunderstanding, but I assumed that workflow is controlled by assigning tasks to user groups  (Task A, User group 1 starts, at the task end User Group 2 receives result of Task A, processes the results as Task B, ......).
I know, a complete newbie questions. I appreciate any insight - thanks a lot!
-Tobias
tkriegerAnswer
Nov 17, 2016 1:52 PM UTC
...so after testing my answer is that the "user group" in the FRACAS incident table can't be switched by another user, only by admin. My initial thought, assign a task by switching from one user group to another one does not work (at least not if you use the field $(group). It is possible to add a list similar to the user groups and just use this one.
-Tobias
tkrieger1-VisitorAuthorAnswer
-Tobias
