May 31, 2017 6:16 AM UTC
General question in Case Branch (OIR)
Hello Everyone
I want to create a product number based on attribute selection.
On selecting the attributes the product number has to be created automatically choosing the number given for the particular attribute.
For example:
Customer No.       Product Family     Running No.
      XXX                         YY                    ZZZ
If the product attribute selection be like 032(Customer no.)12(Product family) 322(running no.)
The auto generated number should be like 03212322
I'm able to create the numbering schema for customer name using case branch in OIR. But I have no clue in combining both the customer no. as well as product family (XXXYYZZZ)
Can anyone help in this?
Any help is greatly appreciated.
BenPerry
May 31, 2017 11:35 AM UTC
Vasantha Kumar‌,
Essentially what you're saying is that you have 2 attributes and a sequence.  And you want the number of the object to be a concatenation of those 3 attributes.  Is that what you're asking?
I can't remember where I got this code from.  I think there is an article on it.  But I couldn't find it doing a quick search.  But I have a WTDocument OIR that will set the name as a concatenation based on 2 things:
  1. The selection of an attribute.
  2. Something hard coded.
  <AttrValue id="name" algorithm="com.ptc.windchill.enterprise.revisionControlled.server.impl.NumberGenerator" ignore="false" force="false" final="false">
    <Attr id="partQualGenPartNumber"/>
    <Arg>: PART QUALIFICATION PROCESS</Arg>
  </AttrValue>
So if you wanted to set the number of the object based on 2 attributes and a sequence, perhaps something like this would work?:
    <Attr id="customerNumberIBAinternalName"/>
    <Attr id="productFamilyIBAinternalName"/>
    <Attr id="runningNumber"/><Arg>{GEN:wt.enterprise.SequenceGenerator:YOUR_DATABASE_SEQUENCE:3:0}</Arg>
<AttrValue>
vasanth1-VisitorAuthor
May 31, 2017 12:20 PM UTC
Thanks for your valuable reply sir.
Will try and let you know if I face any difficulties.
Jun 1, 2017 3:54 PM UTC
Greetings,
What I did for my particular application was create a definition variable concatenating the desirable attributes. The code snipped is as follows:
<AttributeValues obType="wt.doc.WTDocument">
<VarDef id="generatedNumber" algorithm=ext.xxxxxxxx.doc.DocNumberGenerator"> (xxxxxx can be your unique identified; name etc.; this generates a sequential unique identifier)
     <Attr id="Attribute1'/>
     <Attr id="Attribute2'/>
     <Attr id="Attribute3'/>
     <Arg>-</Arg> (if you want to separate the concatenated attributes with a hyphen)
</VarDef>
<AttrValue id="number">
     <VarRef id="generatedNumber"/>
</AttrValue>
{Basically, the above snippet concatenates all your attributes and stores them in the variable 'generatedNumber', then recalls the value and places it in 'number' holder in Windchill.} - [For example; this would result in "Attribute1-Attribute2-Attribute3-001]
Hope this helps!
Cheers
Jas Virdee
