Feb 7, 2025 6:23 AM UTC
generate correct number sequence.
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.0
I Have created new sub type of ECN and created new number sequence for that, but it did not generate correct number sequence.
Catalina
Community Manager
Feb 7, 2025 1:21 PM UTC
Hi @PG_10425714
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Furthermore, please consult this Community Search guideline as well, which boosts up your chances of finding a resolution to your topic(s) much faster.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina | PTC Community Manager
avillanueva
23-Emerald II
Feb 7, 2025 1:22 PM UTC
Kind of need more here. Perhaps show us your OIR file and some screenshots and what your intended sequence was to be. Please rework your question.
Feb 7, 2025 3:13 PM UTC
If you are using a database sequence generated number, it will jump depending on your settings in the DB. The numbers tend to 'restart' at an increment of 10 by default, depending on how long since the last number was pulled.
More details about what you want and a copy of that section of your OIR will help us.
