Mar 8, 2016 10:14 AM UTC
Generate "EPM Windchill Structure" as default representation
Dear,
We just started to work with Widchill 10.2 M30 and I found this new functionality under an EPM document to be able to see the 3D model in the Visualization tab.
Do you know if it's possible to generate automatically the EPM WIndchill Structure by the click on the Representation Thumbnail.
Today, we generate only a PDF and DWG Representation.
Thanks in advance
Frederic
23-Emerald II
Mar 9, 2016 4:25 PM UTC
Currently, there is no setting or preference to specify the default structure type used when automatically generating default representations. Do you not get the same type of representation then when you use the EPM Only structure type? Are you publising drawings or the parts and assemblies, too?
