Oct 29, 2015 5:30 AM UTC
Get EPMDocument of children of assembly
I am using Windchill 10.2. I am trying to download assembly as well as its child parts with correct version(Not latest) using JAVA APIs.
Here is the situation -
I created one Assembly A with version 1.1 has 2 parts P1 with version 1.1 and P2 with version 1.1. Now I changed P2 and checked-in assembly again. So assembly version becomes 1.2, P1 is still 1.1 but P2 moves to 1.2.
A (1.1)                              A (1.2)
    |---- P1 (1.1)                         |---- P1 (1.1)
    |---- P2 (1.1)                         |---- P2 (1.2)
Now, I want to download Assembly with version 1.1 and its children, P1 and P2, both having version 1.1. I am doing following to get EPMDocument of assembly.
QuerySpec qSpec = new QuerySpec( EPMDocumentMaster.class );
qSpec.appendWhere( new SearchCondition( EPMDocumentMaster.class, EPMDocumentMaster.NAME, SearchCondition.EQUAL, "abc.asm") );
QueryResult qrMasters = PersistenceHelper.manager.find( qSpec );
QueryResult qr = VersionControlHelper.service.allVersionsOf( (Mastered)qrMasters.nextElement() );
EPMDocument epmDocument;
while ( qr.hasMoreElements() ) {
  epmDocument = (EPMDocument) qr.nextElement(); <-- Here I got EPMDocument of Assembly
  VersionInfo versionInfo = epmDocumentTemp.getVersionInfo();
  if ( versionInfo.getIdentifier().getValue().equals("1") ) {
      break;
Now I got EPMDocument. I want to know its children. For this,
QueryResult qr = EPMStructureHelper.service.navigateUses(  epmDocument, null, false);
Enumeration enum1 = qr.getEnumeration();
while (enum1.hasMoreElements()) {
    EPMMemberLink aEPMMemberLink = (EPMMemberLink) enum1.nextElement();
Here, I want to know EPMDocument of each child of assembly.
When I do,
EPMDocumentMaster aEPMDocumentMaster = (EPMDocumentMaster) aEPMMemberLink.getUses();
QueryResult qr1 = VersionControlHelper.service.allVersionsOf(aEPMDocumentMaster);
EPMDocument doc = (EPMDocument) qr1.nextElement();
I always get document of latest iteration. I want the one that is referenced by assembly of earlier version. How do I find this? I am more interested in knowing its iteration number.
Oct 29, 2015 1:42 PM UTC
Hello Swapnil.
I haven't coded in a while; but there is a way to filter the child masters based on a config spec.  Look for documentation on ConfigHelper.service.filteredIterationsOf()
You can then either provide the system created "As-stored" configuration or a baseline to get the version of the children you want.
"As-Stored" gives you the versions in the Workspace when the assembly was checked in.
I hope this points you in the right direction.
Jennifer
Oct 29, 2015 3:59 PM UTC
Jennifer,
Off topic here...but that is the best and clearest explaination I've seen on the definition of "As Stored".  Do you have a simple description for Baseline?  Maybe Baseline is just a fancy way of creating an As stored structure without using the workspace checkin process?
Oct 30, 2015 8:30 AM UTC
Hello Bill.
As Stored is like a baseline of:
-  the objects you are checking in (their checked in version)
- PLUS the version of all children in the workspace.
As stored is more complicated than a baseline, because:
- It maintains information about why objects are in the configuration (i.e. they were being checked in or they were a dependent)
- It has special behavior for purge and delete such that they do not prevent delete and the as-stored becomes incomplete.
I hope this helps.
Jennifer
20-Turquoise
Oct 29, 2015 9:50 PM UTC
Swapnil: Also take a look at the CadCollector api described in this article:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS81089
I have used this successfully to retrieve related drawings and wtparts. I haven't actually used it to retrieve the dependents of an asm.
Randy
Oct 30, 2015 11:26 AM UTC
I am not able to use CadCollector. What is the JAR file name for this or how should I reference it?
20-Turquoise
Oct 30, 2015 1:46 PM UTC
Looking up CadCollector in the Windchill java docs or hovering over CadCollector in Eclipse shows this:
com.ptc.windchill.collector.api.cad.CadCollector
and this resides in the codebase/WEB-INF/lib/wncWeb.jar jar file:
root@wct02:/opt/ptc/Windchill/Windchill/codebase/WEB-INF/lib# jar tvf wncWeb.jar | grep -i cadcollector
   259 Fri Sep 25 23:44:40 CDT 2015 com/ptc/windchill/collector/api/cad/CadCollector$1.class
  1471 Fri Sep 25 23:44:40 CDT 2015 com/ptc/windchill/collector/api/cad/CadCollector$GatherAssociatedParts$1.class
  2417 Fri Sep 25 23:44:40 CDT 2015 com/ptc/windchill/collector/api/cad/CadCollector$GatherAssociatedParts.class
  1716 Fri Sep 25 23:44:40 CDT 2015 com/ptc/windchill/collector/api/cad/CadCollector$GatherDependents$1.class
  2586 Fri Sep 25 23:44:40 CDT 2015 com/ptc/windchill/collector/api/cad/CadCollector$GatherDependents.class
  1450 Fri Sep 25 23:44:40 CDT 2015 com/ptc/windchill/collector/api/cad/CadCollector$GatherDrawings$1.class
  2361 Fri Sep 25 23:44:40 CDT 2015 com/ptc/windchill/collector/api/cad/CadCollector$GatherDrawings.class
  1457 Fri Sep 25 23:44:40 CDT 2015 com/ptc/windchill/collector/api/cad/CadCollector$GatherFamilyGenerics$1.class
  2398 Fri Sep 25 23:44:40 CDT 2015 com/ptc/windchill/collector/api/cad/CadCollector$GatherFamilyGenerics.class
  1562 Fri Sep 25 23:44:40 CDT 2015 com/ptc/windchill/collector/api/cad/CadCollector$GatherFamilyMembers$1.class
  2502 Fri Sep 25 23:44:40 CDT 2015 com/ptc/windchill/collector/api/cad/CadCollector$GatherFamilyMembers.class
  2146 Fri Sep 25 23:44:40 CDT 2015 com/ptc/windchill/collector/api/cad/CadCollector$Kind.class
  1549 Fri Sep 25 23:44:40 CDT 2015 com/ptc/windchill/collector/api/cad/CadCollector$Type.class
  6665 Fri Sep 25 23:44:40 CDT 2015 com/ptc/windchill/collector/api/cad/CadCollector.class
