Jul 18, 2015 1:41 PM UTC
Getting errors while starting the windchill server- Prod down
In order to remove unreferenced files from the vault wanted to set the wt.fv.purgeUnreferencedFilesOlderThan =2
I just did the following steps as initial step for removing the .unreferenced files:
1) Updated site.xconf to set wt.fv.purgeUnreferencedFilesOlderThan =2
2) Ran xconfmanager –p from Windchill home directory
3) No error reported
4) Stopped Windchill
5) Cleared tomcat instances
6) After that tried to start the method server but it’s not starting
Getting following error
Exception in thread "main" java.lang.reflect.InvocationTargetException
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
        at java.lang.reflect.Method.invoke(Method.java:597)
        at wt.manager.ServerLauncher.startServerReturningProcess(ServerLauncher.java:143)
        at wt.manager.ServerLauncher.startServer(ServerLauncher.java:101)
        at wt.manager.ServerLauncher.main(ServerLauncher.java:472)
Caused by: java.lang.IllegalArgumentException: Empty command
        at java.lang.Runtime.exec(Runtime.java:425)
        at java.lang.Runtime.exec(Runtime.java:369)
        at wt.manager.ServerLauncher.launchCmd(ServerLauncher.java:236)
        at wt.manager.ServerLauncher.launchCmd(ServerLauncher.java:208)
        at wt.manager.ServerLauncher.launchCmd(ServerLauncher.java:192)
        at wt.manager.BaseServerLauncher.launch(BaseServerLauncher.java:249)
        at wt.manager.BaseServerLauncher.launch(BaseServerLauncher.java:122)
        ... 7 more
Any idea why this error is showing up? Please let me know currently our prod servers are not starting.
2-Explorer
Jul 18, 2015 6:18 PM UTC
Make sure the value of wt.manager.cmd.ServerManager or wt.manager.cmd.MethodServer propoertis are correct in wt.properties. If it is a unix system, make  wt.manager.cmd.executor  is set to blank
Binesh
Barry Wehmiller
2-Explorer
Binesh
Barry Wehmiller
rpaul-21-VisitorAuthor
Jul 20, 2015 10:56 PM UTC
hanks a lot!! You had saved my day. That worked. As you had mentioned the properties were not set properly in wt.properties. But I didn’t change those attributes just modified the attribute swt.fv.purgeUnreferencedFilesOlderThan =2 and ran xconfmanager –p from Windchill home directory. Then how did those attributes get updated?
Jul 20, 2015 10:57 PM UTC
Thanks a lot!! You saved my day. That worked. As you had mentioned the properties were not set properly in wt.properties. But I didn’t change those attributes just modified the attribute swt.fv.purgeUnreferencedFilesOlderThan =2 and ran xconfmanager –p from Windchill home directory. Then how did those attributes get updated?
