Jul 7, 2017 5:54 AM UTC
Getting the container name in OIR
Hi Everyone,
I need to get the container name in th format of string in my OIR to set some custom attribute. The attribute "containerReference" does not exactly equal to the container name as we use wtContainerRef.getName(); to get this.
Can any one tell how to get this?
<AttrValue id="view.id">
<Value algorithm="wt.rule.algorithm.BooleanBranch">
<Value algorithm="wt.rule.algorithm.StringEqualsTest">
<Attr id="containerReference"/>
<Arg>Test Product</Arg>
</Value>
<Arg>YES</Arg>
<Arg>NO</Arg>
</Value>
</AttrValue>
2-Explorer
Jul 7, 2017 10:13 AM UTC
Could you try containerName instead of containerReference?
jselvaraj1-VisitorAuthor
Jul 7, 2017 12:23 PM UTC
Dear Binesh,
Thanks for your reply..
I tried the same.. however it is not seems to be working...
Jul 24, 2017 6:06 PM UTC
Can you set loggers on wt.rule.algorithm.StringEqualsTest class , if it is 10.2 M020 or earlier version enable verbose wt.rule.algorithm.StringEqualsTest.verbose in wt.properties . This will let you know what are the arguments passed to this rule algorithm.
Bhushan
Jul 24, 2017 7:43 PM UTC
What are you trying to do with the view.id? I just opened up a case to get me some examples to set a default view for different part subtypes. This doesn't work anymore with setting it thru the OIR.
This also could be a problem...
Jul 25, 2017 8:03 AM UTC
Hi, My original requirement is to set different view for different containers. The View should be read only and should not be editable.
Thanks.
Jul 25, 2017 8:29 AM UTC
That's almost also my requirement. Unfortunately to set the view.id within the OIR is not supported anymore.
Jul 25, 2017 5:27 AM UTC
I am not sure about your exact requirement. But it seems like Part view can’t be set from OIR see below article https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS30181
Shreyas
Jul 25, 2017 5:31 AM UTC
That is what I'm trying to say Smiley Wink
The OIR trys to set the following attribute
Since this doesn't work, I guess the container name is being filled out correcty, just the view.id will not being set.
