18-Opal
Jun 24, 2015 4:15 PM UTC
Getting the report into the users hands
Hey, what is the secret to get the report I just created into the user's hands so they can use it?
I created a report for tracking some change management information and it works!!  Step one done.  Now how do I get that report in the hands of a regular user to be able to run at will?  I created the report at the ORG level as orgadmin.
Windchill 10.1 m040
- marc
CAD / PLM Systems Manager
MarcoTosin
Jun 24, 2015 4:26 PM UTC
Marc, you have to make your report ready to use.
In the query builder help guide you can find how to do it.
Marco
mdebower18-OpalAuthor
18-Opal
Jun 24, 2015 4:32 PM UTC
Hey Marco,
I found a link in the Reporting document that goes to a TS article that indicates you have to do it at the SITE level.  Can I do the same thing at the ORG level?
Jun 24, 2015 4:41 PM UTC
‌Sorry, not Marco .... Who beat me in answering first. Anyways https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS52000&art_lang=en&posno=1&q=report%20access&source=search  where I just lifted the two steps from in my other answer talks about that to expose org level reports you need to adjust OOTB access rules too.
Jun 24, 2015 4:31 PM UTC
Its quite well hidden in the UI - and of top of that has two steps:
  1. Edit the Report in Query Builder or Report Manager: Select Report > Properties and check Expose As Report
  2. Edit the Report from Organization > Reports, check Ready For Use, select Home (or desired Context) in Display Context(s) section and click Ok
