Sep 13, 2016 12:57 PM UTC
getting the root node, when checking in updated content
I am able to burst a document and its images into ACM, creating the correct folder structure based on the xml. But when i check out a piece of that content and add an image, then check it back in, i am unable to get the root node of that content. The Root node contains the values i need to the folder structure, thus the image is being saved in a default place - 'No MetaData'. Here is the image path code form the burst config.
<locnhook sourcetype="graphic" type="acl"><![CDATA[function ln_burst::generate_graphic_path(oid)
  local tagname = oid_name(oid);
  local folder_name;
  local arr[1];
  local doc = oid_doc(oid);
  # All elements get stored in the Library
  folder_name = '/Libraries/Commentaries Work-Academic';
  # get the publication title
  # EX:  Fundamentals of Financial Planning
  if(defined($main::BURSTINFO[$doc.'.pub_folder'])) { folder_name = $main::BURSTINFO[$doc.'.pub_folder']; }
  else
     # the publication title is needed for folder name
    local publication_name;
   local publication_subject;
  if(defined($main::BURSTINFO[$doc.'.publication_name'])) {
  publication_name = $main::BURSTINFO[$doc.'.publication_name'];
  publication_subject = $main::BURSTINFO[$doc.'.publication_subject'];
  else {
  if(oid_root()){
  if(oid_attr(oid, "dc.title")){
  publication_name = oid_attr(oid, "dc.title");
  publication_subject = oid_attr(oid, "dc.subject");
  else{
  publication_name = 'No MetaData';
  # store in global array
  if(!defined($main::BURSTINFO[$doc.'.publication_name'])) {
  $main::BURSTINFO[$doc.'.publication_name'] = $publication_name;
  $main::BURSTINFO[$doc.'.publication_subject'] = $publication_subject;
    folder_name .= '/' . $publication_subject;
    # use first letter of name for alpha index folder
  if($publication_name = "No MetaData"){
  folder_name .= '/NM';
  else{
    folder_name .= '/' .substr($publication_name, 1, 1);
    # append the publication title
    folder_name .= '/' . $publication_name . '/';
  # level, index and toc folders are done, else...
  # assign folder for element
  # Images
  folder_name .= 'Images';
  #local fid=open('D:\Source\XML\BurstDevLog.txt', "a+");
  #put( fid, "folder name: $folder_name" );
  #put( fid, "\n " . time_date() . "\n" );
  #close(fid);
  if(index(folder_name, '&')) {
    gsub('\&ldquo;', '"', $folder_name);
    gsub('\&rdquo;', '"', $folder_name);
    gsub('\&rsquo;', "'", $folder_name);
    gsub('\&lsquo;', "'", $folder_name);
    gsub('\&amp;', "and", $folder_name);
  if(!defined($main::BURSTINFO[$doc.'.pub_folder'])) {$main::BURSTINFO[$doc.'.pub_folder'] = folder_name;}
  return folder_name;
dms::set_burst_hook_value(ln_burst::generate_graphic_path(dms::burst_hook_first_oid()));
]]></locnhook>
