3-Newcomer
Apr 10, 2025 4:52 AM UTC
Got version 8 INIT FAILURE (with no description) from WVS.
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.1.0
1. I wanted to Configure addtional Worker for Solidworks (Server PCs are different)
2. Adapter, Worker Agent installation and configuration have done.
However, the connection between Worker and Windchill is disconnected right after turning on the Worker.
Here are the error logs that I got
==== Log ====
[2025-04-09 09:53:34] workermonitor - Version : 19.0.0.0-O5U3hr x86e_win64
[2025-04-09 09:53:34] Logging level set to 0x01.
[2025-04-09 09:53:34] Connecting to server "XXXXXXX.co.kr" on port 5600
[2025-04-09 09:53:34] Monitor keep alive set - 300000 milliseconds
[2025-04-09 09:53:34] Connection established
[2025-04-09 09:53:34] Got version 8 INIT FAILURE (with no description) from WVS.
[2025-04-09 09:53:34] Monitor Shutting down.
3-Newcomer
Apr 10, 2025 4:59 AM UTC
To add, All the settings in eSupport thechnical document have been done.
Everything has done and normal.
avillanueva
23-Emerald II
Apr 10, 2025 11:24 AM UTC
https://www.ptc.com/en/support/article/CS38577?source=search
https://www.ptc.com/en/support/article/CS347525?source=search
https://www.ptc.com/en/support/article/CS345574?source=search
See if this identify your issue. Can you post what you have for your batch file startup? You can obfuscate the hostnames and starting paths for security. Just make sure they are correct. Also what you have for worker setup on Windchill side. It sounds like your error is a mistake on one side or the other.
