7-Bedrock
May 6, 2024 9:57 AM UTC
Group By This Field option in Workspace to group the objects by specific column
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.13
In commonspace there is a possibility to use the option "Group By This Field" of most of existing columns.
This option is not available in Workspace either on server-site or local workspace (Workgroup Manager).
Is there a reason or restriction why this is not available?
    Fadel
    23-Emerald II
    May 7, 2024 2:54 PM UTC
    There is already an Idea to change this fact https://community.ptc.com/t5/Windchill-Ideas/Add-Group-By-This-Field-and-Show-in-Groups-to-Workspace-Tables/idc-p/788123#M14774%3Fsource=search
    for the reason , I think it is the technology used the folder view is JCA based n while the workspace  is a form porcessor
    Buiꓘa
    18-Opal
    May 10, 2024 3:24 PM UTC
    Hello AKrehl_6674,
    Will you need further information here?
    KR,
    Charles.
    7-Bedrock
    May 16, 2024 7:44 AM UTC
    Hello Charles,
    for me it is not clear if this is a technical restriction and can't be implemented?
    I see also the existing Idea which was closed because of less votes.
    Makes it sence to create a new Idea based on this topic with the hope that this function can be implemented?
    Andreas
    HelesicPetr
    May 16, 2024 7:52 AM UTC
    Hi @A.Krehl_6674
    Yes create the Idea.
    PetrH
