Aug 2, 2023 11:17 AM UTC
Has any did the bulk load method to obsolete existing WTDocuments?
We are in need to obsolete a bunch of existing WTDocuments.  I have done creating new WTDocument using Bulk Upload method, but I have not done Obsolete existing WTDocument before.  Has anyone done this before?  If yes, can you share the xml recipe file if you can?
Thank you,
tchaoAnswer
Aug 2, 2023 1:53 PM UTC
This xml file is working, but just that I need to change from this line:
<csvDocument handler="wt.doc.LoadDoc.createGeneral" >
to this line to get it working:
<csvDocument handler="wt.doc.LoadDoc.beginCreateWTDocument" >
The first one gave me and error and the change works and obsoletes the WTDocument.
Thank you.  I will create a recipe file for it.
HelesicPetr
Aug 2, 2023 12:20 PM UTC
Hi @tchao
In your XML you need to define lifecyclestate element where you set a obsolete state. The value is internal name of the state.
Also during the import/creation user needs to have a rights to modify that state, for example as a administrator.
<?xml version="1.0" ?><!DOCTYPE NmLoader SYSTEM "standardX20.dtd">
<NmLoader>
 <csvuser></csvuser>
 <csvname>DOCUMENT123.pdf</csvname>
 <csvtitle>DOCUMENT123.pdf</csvtitle>
 <csvnumber>DOCUMENT123.pdf</csvnumber>
 <csvtype>Document</csvtype>
 <csvdescription></csvdescription>
 <csvdepartment>DESIGN</csvdepartment>
 <csvsaveIn>/Default/Test_import/</csvsaveIn>
 <csvteamTemplate></csvteamTemplate>
 <csvdomain></csvdomain>
 <csvlifecycletemplate>Two Phase Development</csvlifecycletemplate>
 <csvlifecyclestate>OBSOLETE</csvlifecyclestate>
 <csvtypedef>com.ptc.ReferenceDocument</csvtypedef>
 <csvprimarycontenttype>ApplicationData</csvprimarycontenttype>
 <csvpath>D:\\fileContent.pdf</csvpath>
 <csvformat></csvformat>
 <csvcontdesc></csvcontdesc>
 <csvversion>A</csvversion>
 <csviteration></csviteration>
 <csvsecurityLabels></csvsecurityLabels>
</csvDocument>
</NmLoader>
PetrH
tchao10-MarbleAuthor
Aug 2, 2023 12:41 PM UTC
Thank you.  I will give this a try and let you know how it goes.
tchao10-MarbleAuthorAnswer
