Mar 7, 2016 6:31 PM UTC
Has anyone successfully setup Form based login with Windchill 10.1 +,
Has anyone successfully setup form based login with Windchill 10.1+?
If you have been able to do it,
  • What is the expected behavior when hitting the initial Windchill page?
The documentation is unclear on whether the web server must be configured to redirect the user to the login page,  or if Windchill itself detects no REMOTE_USER header variable and redirects the user to the submitURL location.
  • Any issues with using Desktop Integration or Creo clients?
Thanks,   Any information would be greatly appreciated.
Mar 8, 2016 11:18 AM UTC
Hi
I have done similar configuration but using ADFS and shibboleth, the behavior was (and I think with web-based authentication it should be the same) that the server detects if the user is not connected and redirect him to login page.
6-Contributor
Sep 12, 2018 9:01 AM UTC
Hi ,
Could you please share the details how you configured the SSO with ADFS ?
ShirishMorkhade
Mar 9, 2016 1:01 PM UTC
Hi Duane,
I have not personally tried this but you can have a look at this:
http://www.ptc.com/cs/help/windchill_hc/wc101_hc/index.jspx?id=WCAdvDepAuth_ConfigAltAuth&action=show‌
Section :: Form-based Authentication
I hope this help you.
Best Regards,
Shirish
