Jun 14, 2016 3:37 PM UTC
Having a problem wih non-working days in the System Calendar, anyone know a fix ?
When trying to set non-working days in the System calendar for the months of November thru March, the action button is greyed out. Anyone experience that ? Any work around ?
Jun 14, 2016 5:19 PM UTC
Is the following property set?
wt.calendar.calculateDefaults=false
If you're able to designate smaller chunks of time as non-working (for example, a single week at a time), then it might be an issue with trying to select multiple months at once - I believe I had a bit of an issue with that at once time.
dthompson1-VisitorAuthor
Jun 14, 2016 5:54 PM UTC
Thanks, yes that property is set. However, my issue is not with the entire calendar, it is only the months Nov thru March that will not work, the other months work just fine.
We also have
   wt.calendar.nonWorkDaysOfTheWeek=1,7
set in the properties file as well, and that sets Saturday & Sunday as non working days for most months, but the problem months (Nov - March), don't have them set as well.
Jun 14, 2016 6:04 PM UTC
To clarify, are you talking about next November through March (Nov 2016 - March 2017) or are you trying to edit past months (Nov 2015 - March 2016)?
Looking through our knowledge base, it looks like a few similar problems might have been solved using the "Reset All" action. Can you try that?
