May 24, 2017 10:57 AM UTC
Having issues with removing the Tabs for the information page in windchill 10.2
I have been working on custom UI screens, and the requirement from my global engineering community is to reduce the number of TABS in the InfoPage for each object type.
So far I have been able to remove the following:-
-"Traceability TAB" by changing the user preferences "show traceability tab" to "NO"
For the other tabs I used CS56580 as a guide:-
-For "Documents", I have removed the "Structure, Content, Related Objects, Changes, History, Traceability and Relationship Explorer TABs, by adding the "docInfoPageTabSet" code copied from the DocumentsManagement-actionmodel.xml into the Custom-actionmodels.xml file and removing the afore mentioned tabs.
-For "Parts", I have removed the "Structure, Content, Related Objects, Changes, History, Where used and Relationship Explorer TABs, by adding the "partInfoPageTabSet" code copied from the PartClient-actionmodel.xml into the Custom-actionmodels.xml file and removing the afore mentioned tabs.
I cannot find how to do the same for Creo parts, assemblies, models and drawings, where is the code for these? or if these use a different method of customisation?
