Mar 7, 2024 5:12 AM UTC
Hi Team, Please help me in generating a qml report All WTParts for which representation is missing.
I am using Windchill PDMLink Release 11.2 and Datecode with CPS 11.2.1.17
Hi Team,
Please help me in generating a qml report All WTParts for which representation is missing. I tried from my side but I am not able to do it.
Regards
Anil
    MarcoTosin
    Mar 7, 2024 7:18 AM UTC
    Take a look at this article
    Report to list all EPM Documents without representations
    You can also look up what you asked for in the PTC Support KB.
    https://www.ptc.com/en/support
    You may also read this page
    ptc.com/en/support/wnc-reporting-landing/wnc-reporting-landing-main
    Marco
    Mar 13, 2024 4:26 AM UTC
    Hi Marco,
    Thank you for sharing the links. But my requirement is for WTParts with no representation. I tried to use the same logic and criteria that is used for EPM in the link for my requirement, but the report is pulling the WTParts with and without representation.
    Anyway thank you for your time.
    Regards
    Anil
    MarcoTosin
    Mar 13, 2024 7:12 AM UTC
    Try to use this report and a sub select like the one in the EPMDoc report
    Query Builder report to display WTParts having representations in Windchill PDMLink
    And also this article could help
    How are Representations stored in the database and how are EPMDocuments linked to them in Windchill PDMLink
    • The CLASSNAMEKEYTHEREPRESENTABLE and IDA3THEREPRESENTABLEREFERENCE columns in the DerivedImage table can be used to identify the Representable (which could be a WTPart or an EPMDocument).
    Marco
    Mar 13, 2024 5:34 AM UTC
    Hi Anil,,
    Have you tried creating a publish scheduler job. Refer the steps mentioned in CS338535.
    Let us know if that helps.
    regards
    ~Syed
    Mar 13, 2024 6:23 AM UTC
    Hello Syed,
    I have tried this before to get the report from WVS JOB SCHEDULER but it is giving results in below format shown in the image. It is very difficult to get the columns like container name, Latest iteration/version. this did not helped me.
    Thank you for your time.
    Regards
    Anil
