Jul 25, 2014 6:30 AM UTC
Hide/Show a wizard step based on type selected
Hi all,
I want to hide/show Step 2 of a wizard based on the type selected in Step 1. Have anyone done anything similar in javascript? Any help is appreciated.
ShirishMorkhade
Aug 8, 2016 7:06 PM UTC
Hi Praseeth Moothedath
You question is not clear to me as which wizard your taking about - New Part wizard, New Change Request wizard or some other.
I recently work on such requirement where I wanted to hide/show Affected Objects wizard step for one of sub type. And I add below JavaScript to "<WT_HOME>\codebase\netmarkets\jsp\changeRequest\create.jsp" file and it worked for:
<script language="JavaScript">
  PTC.driverAttributes.on("afterRefresh",function() {
      customToggleCreateCADDocStep('affectedDataStep');
  // wizard step should be in format type.action
  function customToggleCreateCADDocStep(wizardStep) {
  var type_beingCreated = document.getElementById("createType").value;
  var allowed_type1 = "wt.change2.WTChangeRequest2";
  var allowed_type2 = "wt.change2.WTChangeRequest2|com.ptc.ptcnet.SubTypeTest1";
  if (type_beingCreated == allowed_type1 || type_beingCreated == allowed_type2) {
       insertStep(wizardStep);
  } else {
       removeStep(wizardStep)
</script>
Shirish
avillanueva
23-Emerald II
Jun 24, 2024 11:49 PM UTC
Not quite the same but I modified the create and edit doc jsp to add hidden steps. In the code that is called, it checks the type of the document.
<jca:wizard buttonList="${buttonList}"
helpSelectorKey="DocMgmtDocEdit" title="${title}">
<jca:wizardStep action="editAttributesWizStep" type="object"/>
<jca:wizardStep action="setClassificationAttributesWizStep" type="classification"/>
<jca:wizardStep action="attachments_step" type="attachments" />
<%--- Customizations for Electrical Eng Docs --%>
<%-- process if matches drawings as documents --%>
<jca:wizardStep action="process_drw_docs" type="document" />
<jca:wizardStep action="process_schematic" type="document" />
</jca:wizard>
