Jan 26, 2017 1:46 PM UTC
How can I bulk remove users from windchill?
Can anyone tell me how can I bulk remove users from windchill 10.2 please?
I can only import 50 users in to the participant administration and I have to remove 1400+ disconnected users.
Is there a way that I can remove all disconnected users at once?
Thank you in advance for any guidance you can give.
2-Explorer
Jan 26, 2017 2:31 PM UTC
If you are familiar with the database side, you can update the DB tables directly
  1. delete from RemoteObjectInfo where idA3A3=<idA2A2 from "select ida2a2 from wtuser where name like '%USERNAME%>;
  2. delete from OwningRepositoryLocalObject where idA3B5=<idA2A2 from "select ida2a2 from wtuser where name like '%USERNAME%>;
  3. Update WTUser set name=’{wt.org.wtuser:’ + CAST(idA2A2 as varchar) + ‘}’ + name, disabled=1, repairNeeded=0 where idA2A2=<"select ida2a2 from wtuser where name like '%USERNAME%>;
2-Explorer
sconrad1-VisitorAuthor
Feb 3, 2017 12:55 PM UTC
Thank you for your input. I was asked not to do it from the DB for whatever reason... I ended up removing 2800+ users 50 at a time... This is something that needs to change. I can't see a valid reason that only 50 users should be removed at once.
Since it takes 5-10 minutes for windchill to remove the users.Doing it 50 at a time took 2 days to complete. I can't imagine how long it would take of we had over 10,000 users to remove.
2-Explorer
Feb 3, 2017 12:59 PM UTC
I think we can increase the limit by setting the property com.ptc.netmarkets.userSearch.maxCount  in wt.properties  to a higher value.
