Dec 29, 2015 6:01 AM UTC
How can I change path to SQL Server (from local to remote) in installed Windchill?
Is there any tools to set another path to SQL Server (remote server) in already installed Windchill?
Thanks.
2-Explorer
Dec 29, 2015 1:29 PM UTC
If you have already ported the database to a different SQL Server machine using database administration tools then it is all about updating the database related properties in WT_HOME/db/db.properties
Look for the below properties in there and update it using xconfmanager commands and restart your Windchill Instance. If you are using cognos, then you should export and import cognos db and update the content manager configuration as well.
  • wt.pom.jdbc.database=
  • wt.pom.jdbc.host=
  • wt.pom.jdbc.port=
  • wt.pom.jdbc.service=
  • wt.pom.dbPassword=
  • wt.pom.dbUser
Thank you,
Binesh
2-Explorer
  • wt.pom.jdbc.host=
  • wt.pom.jdbc.port=
  • wt.pom.dbUser
Thank you,
Binesh
atemnikov1-VisitorAuthor
Dec 30, 2015 6:34 AM UTC
THank you!
