Jan 24, 2025 9:40 AM UTC
How can I create the IPE parameter as an alias in the Cad data and map it?
How can I create an attribute as an alias in the Cad data for the IPE parameter found in the part data and map it?
In my attempt related to this topic, the mapping code "builtBy@wt.epm.build.EPMBuildHistory~built^wt.part.WTPart~IPE" works for data with the same version and iteration. However, I only need the parameter value for that specific version; how can I achieve this?
Emeritus
Jan 29, 2025 11:10 AM UTC
Hi @smcvr,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It also helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team
