Apr 28, 2015 1:36 PM UTC
How can I delete parent child relationships in Windchill/Creo 2.0
I created a simple assembly for checking purposes and a permanent reference was attached to the child even though I deleted that child from the parent assembly. I can't get rid of the assembly from my workspace. Please help.
Apr 28, 2015 2:03 PM UTC
Did you save and uploaded the assembly after you deleted the component from the assembly? What you see in the workspace is an interpretation by Windchill of the relationships between Creo documents. This interpretation is done during the upload, at least, as far as I understand. In the past, I corrected a similar situation by readding the component, save and upload, reremove it, save and upload.
jkatz1-VisitorAuthor
Apr 28, 2015 2:08 PM UTC
I miss spoke...I did check in the assembly to the server. It is from my server 'sandbox' that I cannot delete the assembly.
Apr 28, 2015 2:34 PM UTC
Comment: It seems quite cumbersome that every piece of hardware (child) would have a permanent relationship to every assembly (parent) where it was ever attached and vice versa. I come from an Inventor background and am accustomed to design development using temporary references without permanent consequences.
May 6, 2015 10:18 PM UTC
Yes this is a huge issue when trying to remove anything from the system. What I end up doing is using Purge to remove old iterations of CAD assemblies in order to delete the old iterations.
Funny for wtparts this is an easy task, as they have an actions available to delete old iterations. But no such luck to do this for CAD assembly. So this means we usually never delete anything and just keep files around forever.
