Feb 3, 2026 1:58 AM UTC
How can i find Windchill Demo data for POC and setup guide
Windchill 개념 증명(POC)을 실행해야 합니다. 이전에는 "데모 카탈로그"라는 곳에서 데이터를 구할 수 있었는데, 더 이상 이용할 수 없는 것으로 알고 있습니다. 혹시 데모 데이터를 가지고 계신 분이 있다면 공유해 주시면 감사하겠습니다.
그리고
Windchill의 기본 설정부터 최종 설정까지 모든 내용을 다루는 종합 설치 가이드를 어디에서 찾을 수 있을까요?
고객센터에서 받은 설치 가이드는 너무 복잡합니다. 더 자세한 자료가 있다면 공유해 주시면 감사하겠습니다.
TDTAnswer
18-Opal
Feb 3, 2026 6:15 AM UTC
You can refer to the following link for free 3D data.
https://grabcad.com/library
You can download the files, open them in Creo, and then check in them into Windchill.
Regarding the VM installation, have you checked with your internal system admin or infra team?
18-Opal
Feb 3, 2026 2:37 AM UTC
Hi @JA_13802817,
If you did not load the demo data while installing the Windchill application, you can refer to the following article to install the demo data.
https://www.ptc.com/en/support/article/CS348830?source=search
If you are planning to install Windchill, the following article will be helpful.
https://www.ptc.com/en/support/article/CS44937?source=search
Feb 3, 2026 2:42 AM UTC
Thank you for your reply.
For the demo data,
I need 3D Creo data, drw, frm, asm, prt, and template. I've already checked the links you provided, but they're a bit different from what I'm looking for.
My goal is to install Windchill on a VM and then practice configuring it using Creo data.
I referred to the installation guide, but the explanations are too complicated. Is there a separate guide or summary that clearly explains the VM installation process?
Thank you for your help, but I apologize for the many requests.
Thank you.
TDT18-OpalAnswer
18-Opal
