May 13, 2015 1:12 PM UTC
How can I know witch version of Relex generated a file?
I have some old FTA files that I need to review.
I lost my relex instalation and I am trying to reinstall it.
I have used relex from 2003 to 1012 (at least) and need to know with version I need to install.
Aryldo Russo
Sep 17, 2015 11:29 AM UTC
Aryldo,
it makes no difference which of the currently supported versions (Relex 7.7 (~year 2005) ..... WQS 10.2 (latest version)) you install.
The crucial point is rather which Relex version you have used in the past. If it was 7.7 or later, just use the conversion wizard that is supplied with all supported versions. If it was earlier than Relex 7.7, then contact PTC support.
Thomas
